Matthew Gillespie posted Matthew Gillespie commented
FlexSim 2021 Update 1 Beta Available
FlexSim 2021 Update 1 Beta is now available.
21.1 Release Notes
To get the beta, log in to your account at https://account.flexsim.com, then go to the Downloads section, and click on More Versions. It will be at the top of the list.
The More Versions button does not appear when logged in as a guest account. Subsequently the beta is available only to licensed accounts and accounts that have a license shared with them. Learn more about downloading the best version of FlexSim for your license here.
product announcementbeta
· 2
Sebastian Hemmann avatar image Sebastian Hemmann commented ·
Hi, it would be good to get a "Label" option in Process Times and Setup Times fields of Fixed Resources.
Is it also correct, that (if I open the Script Window of these fields) no code is written in this fields per default?
Matthew Gillespie avatar image Matthew Gillespie ♦♦ Sebastian Hemmann commented ·
@sebastian.hemmann
Yes, it is expected that the code field is blank. This is because the value is not being stored in code unless it can't be stored in a simpler form. Since the values are simple numbers, they are being stored as number data:
You should send your label request to dev@flexsim.com
ben.wilson contributed to this article matthew.gillespie contributed to this article
