FlexSim 2017 Update 2 Beta is available. (updated 22 August 2017)
Release Notes
- Reorganized the User Manual and updated its formatting.
- Added more topics, tutorials, and reference pages to the User Manual.
- Added new Statistics Collector and Calculated Table tools.
- Added new generic charts for plotting statistics gathered with Statistics Collectors and Calculated Tables.
- Updated the pin to dashboard buttons to create and use Statistics Collectors instead of the legacy charts.
- Added a Variant constructor and assignment operator to Vec3 and Color classes.
- Added functionality for copying dashboard charts as images, and pasting images into dashboards.
- Added new interfaces to FlexScript, such as Math, Group, and DateTime.
- Added toNum() and fromNum() methods to the string class.
- Added a setState() method to the Object class that will work correctly with listening to state changes.
- Improved handling of read-only model files.
- Keyboard shortcuts (Ctrl+PageUp and Ctrl+PageDown) and additional enhancements for switching tabs.
- Added the ability to have null values in a bundle.
- Added the ability to make kinematics exclude incline rotation when managing rotations.
- Improved the parenthesis and quote autocomplete functionality.
- Added autocomplete for curly and square brackets.
- Added a new print() command to write to the output console more easily.
- Added support for instanced meshes.
- Updated the animation system so a single shape can have multiple animators from different shape files.
- Changed the assimp 3D importer so that it can extract and load embedded textures.
- Added support for using specular maps and gloss maps.
- Added support for FlexScript dot syntax in SQL queries.
- Added the capability to specify a warmup time in the interactive model run.
- Added options for following objects with the view.
- Improved MTBF/MTTR state listening to use less events and be more precise.
- Updated the Network Navigator to work for an object that is inside a container that is connected to the network.
- Fixed a bug with global variable highlighting and autocomplete.
- Fixed an issue with destroying a TE on a network when it blocks space on the network.
- Fixed a bug with min() and max() when using distribution functions.
- Previously, getting the number of columns in a Global Table using Table.numCols or gettablecols() returned 0 when the number of rows was 0. Column headers and data types are preserved even when there is no row data. These commands now return the number of columns.
- Changed operators to not change their incline rotation when traveling on inclines. This will change location calculations if you have advanced logic based on internal operator locations.
- NodeListArrays like Object.outObjects can no longer be implicitly cast to an Array. Use the toArray() method instead.
- Fixed a bug with animations drawing their first frame instead of their last frame at times beyond the endtime.
- Added a special rule for ambient color {0, 0, 0} to not use the ambient color. This change will make shapes with ambient {0,0,0} to appear brighter. Change the ambient color to a dark gray, such as {1,1,1} if you want them to remain dark.
- Fixed a bug in the shader that dulled specular highlights with the diffuse texture. This may change how shapes look; they may appear shinier now.
- Added the IS NULL and IS NOT NULL clauses to SQL. Math and comparison operators on null values now return NULL. FlexSim's SQL execution engine is now more in line with the SQL ANSI standard regarding null values. Specifically, if you do comparisons or math operations on elements that have null values, this will return null values. This is different than in FlexScript, where a null value acts like 0 in math operations. Also, null values will be ignored in aggregation functions like AVG(). An option to use legacy SQL nulls was added to Model Settings to preserve backwards compatibility. Upgraded models will automatically enable this option, but new models will default to using the SQL ANSI standard for nulls.
- Added support for more SQL query operators, such as the case-when-then-else-end operator and window functions. This adds many new keywords to SQL, meaning that if you used these as column names in older queries, they will create syntax errors in the query parser in this version. To fix this, put square brackets [] around the column name.
- Changed accessing dynamic label properties to use evaluate() instead of value. For example, consider the following code sample:
Variant value = current.MyLabel;
In 17.1 and previous, this code was the same as:
Variant value = current.labels["MyLabel"].value;
In 17.2 we changed it so that this code is now the same as:
Variant value = current.labels["MyLabel"].evaluate();
The difference is in how FlexScript-toggled node values are retrieved. In 17.1 and previous, current.MyLabel would have just given the text that is the FlexScript code. In 17.2, retrieving current.MyLabel will actually evaluate the FlexScript as code. This is consistent with how table values are accessed. If you have old code that explicitly tried to get the code text with current.MyLabel, you will need to update that code in 17.2 to use current.labels["MyLabel"].value.
Process Flow
- Added a Material Consumption and Replenishment template.
- Added functionality for pasting images into Process Flow views.
Conveyor
- Added a Gap-Optimizing Merge Controller Process Flow template.
- Added instanced rendering to improve Render Mode performance.
- Changed Render Mode to be enabled by default.
- Added new visual options for conveyors.
- Improved run speed performance of the Conveyor Module.
AGV
- Added unload-to-empty capability to the AGV Process Flow template.
AStar
- Added a bridge element to the AStar network.
- Added functionality for collision avoidance.
- Improved heat maps for analyzing AStar traffic.
- Changed the path finding algorithm for the AStar navigator. When you tell an AStar traveler to travel to an object, now it will behave more like the default navigator. It will calculate a "threshold radius" around the object, based on the object's size. Then it will only travel to the edge of that radius. This makes it work better especially for loading/unloading to/from rack objects. The travel operation won't commit as much to traveling to the center of the object,because that can be left to the load/unload operation, which determines exactly where in the rack to pick/place the item. However, this change does affect how older models work because it changes the routes that travelers take.
