Phil BoBo avatar image
9 Likes"
Phil BoBo posted Erik Gerritse commented
FlexSim 2018 Beta Available
FlexSim 2018 Beta is available. (updated 8 Dec 2017)
Release Notes
  • Added a new People module. (Try out the Sample Models)
  • Added new dashboard chart templates to quickly collect and display statistics.
  • Legacy charts are hidden by default in the Library and can be enabled through Global Preferences.
  • Removed the basic Person flowitem and renamed the TaskExecuterFlowItem to Person.
  • Added functionality to the List's pull method to allow you to pull an object/node directly (without writing SQL).
  • Updated ODA to be compatible with DWG 2018 shapes.
  • Updated Assimp to be compatible with the latest FBX file format.
  • Added a RegExResult class for iterating over the matches in a regular expression.
  • Lists can now use arrays as partition ids.
  • Added a mechanism for automatically setting the reset position of objects after moving them by setting their resetposition variable to 1.
  • Added a By Lazy Interval update mode to the calculated table.
  • Improved calculated table performance by reducing the amount of table updates.
  • Improved statistics collector performance by reducing the number of updates to Always columns.
  • Table views can now be set as read-only using the grayed attribute.
  • Added an Ignore Warmup option to statistics collectors.
  • Updated OptQuest so that it can run more than 10,000 solutions.
  • Added a pick option for restoring default values in the Global Table's On Reset trigger.
  • The Query test field is now a multi-line text box.
  • The Source now adds labels to items before calling the OnCreation trigger.
  • Updated the table selection for the Excel Import/Export.
  • Improved color options in various dashboard charts.
  • Changed the model update dialog to be able to autosave the model with an incremented number.
  • Added many new animations for the operator and the person flowitem.
  • Updated many stochastic pick options to use getstream() as the default stream parameter.
  • Updated the TaskExecuter to connect to the DefaultNavigator when created.
  • Improved the Group UI.
  • Updated the Library view to not change when clicking on the User Manual view.
  • Changed the Tree view's Explore > As Code so that it closes the tree's edit view.
  • Fixed a bug with list initial contents having old values in label fields.
  • Fixed a bug with the statistics collector chart interface checkboxes.
  • Fixed an OnDropWindow exception.
  • Fixed some exceptions in the Table View when viewing an Array that no longer exists.
Process Flow
  • Added a Date Time Source activity.
  • Added a Wait for Simultaneous Arrivals Before Entry option to the Zone.
  • Added autocomplete for instanced flow labels (current).
  • Added a zoneistokeninsubset() command.
Conveyor
  • Added a Round Robin destination option to the Send Item pick option.
AStar
  • Added a visual option to show the travel threshold for objects.
  • Improved the draw performance and fixed the timing of some graphical updates.
  • Fixed a bug caused by using the distancetotravel() command in conjunction with collision avoidance.
AGV
  • Fixed a bug with redirecting AGVs at times other than On Pre-Arrival of way points.
product announcementbeta
· 23
Matt Long avatar image Matt Long commented ·
Known issue:
  1. Dashboard Quick Library throws exceptions. (Fixed Nov. 20)
  2. Location objects (People) throw exceptions when opening their properties page. (Fixed Nov. 20)
Arun Kr avatar image Arun Kr commented ·
How's the new random stream function getstream() functions in a statistical distribution?
Regards,
Arun KR
Phil BoBo avatar image Phil BoBo ♦♦ Arun Kr commented ·
The commands are documented in the software:
Do you have a specific question about getstream()?
2 Likes 2 ·
Arun Kr avatar image Arun Kr Phil BoBo ♦♦ commented ·
Thanks.
I expect 2018 version will make customers and us happy.
I hope the Date Time Source activity will be included in the 3D Source object as a pick option list of Arrival Style.
I think the feature of it to be needed right now.
Phil BoBo avatar image Phil BoBo ♦♦ David Seo commented ·
You can add a Create Objects activity after the Date Time Source to generate flowitems in the model.
We have no plans to add this functionality to the 3D Source object.
Clair A avatar image Clair A Phil BoBo ♦♦ commented ·
I agree with David, I suggest you add this feature in the dev list. Users will wonder why we can use dates in a process flow source but not in a 3D source.
3 Likes 3 ·
Michael Machado avatar image Michael Machado commented ·
Yes, make sense @Clair A and @david.seo.
Jordan Johnson avatar image Jordan Johnson ♦♦ Michael Machado commented ·
I'll get this on the dev list. Thanks for the feedback!
Erik Gerritse avatar image Erik Gerritse commented ·
hi,
It seems the Excel import is completely broken - is this a problem others are having as well? I can't get it to import either Excel 2016 or Excel 2013 files and it also says the table I have selected doesn't exist every time.
exception: Exception Caught in ExcelAuto::importData(int startrow, int startcol, int rows, int cols, int curtable, double percentdone, double percentmain) object: /Tools/ExcelAuto
exception: Exception Caught in ExcelAuto::importTables(int onreset) object: /Tools/ExcelAuto
exception: Exception Caught in ExcelAuto::doImport() object: /Tools/ExcelAuto
exception: Exception Caught in ObjectFunction101__project_exec_commandlist_excelmultitableimport_node object: MAIN:/project/exec/commandlist/excelmultitableimport/node i: MAIN:/project/exec/commandlist/excelmultitableimport/node class: MAIN:/project/exec/commandlist/excelmultitableimport/node
exception: Exception caught in TreeNode::callMemberFunction() c++/dll execution. Throwing... MAIN:/project/exec/commandlist/excelmultitableimport/node c: MAIN:/project/exec/commandlist/excelmultitableimport/node i: MAIN:/project/exec/commandlist/excelmultitableimport/node thisClass: MAIN:/project/exec/commandlist/excelmultitableimport/node
exception: Exception caught in evaluation of MAIN:/project/exec/commandlist/excelmultitableimport/node
Jordan Johnson avatar image Jordan Johnson ♦♦ Erik Gerritse commented ·
Can you send in a model and excel file that demonstrate the problem? I tried a few excel files, but couldn't replicate the issue.
Erik Gerritse avatar image Erik Gerritse Jordan Johnson ♦♦ commented ·
demo-broken-excelfile.zip
Hi Jordan,
Here's an empty model and excel file which cause the same error for me.
Erik Gerritse avatar image Erik Gerritse Erik Gerritse commented ·
seems to have been fixed in the beta update, thanks!
phil.bobo contributed to this article jacob.gillespie contributed to this article
