FlexSim 2020 Update 1 Beta is available. (Updated 24 March 2020)
Release Notes
- Updated the Statistics Collector to be simpler and more user friendly.
- Added a PowerPoint FlexScript API.
- Added an HTTP FlexScript API.
- Added a sorting tab to various charts.
- Improved performance of chart templates.
- Replaced the code profiler with a new Performance Profiler.
- Added a Memory Profiler.
- Added OnEntry and OnExit events to TaskExecuter objects.
- Added an icon to library items that launch a pop-out library of choices.
- Reorganized the dashboard library using the pop-out library to consolidate charts with multiple visualizations.
- Updated the WebServer to use the Version Selector.
- Added a Find/Replace UI for global tables.
- Added support for Ctrl-F and Ctrl-H keyboard shortcuts for various windows.
- Added support for renaming objects using the F2 keyboard shortcut.
- Added a Vec3 overload to the Object.setRotation() method.
- Added a stop parameter to the userinput() command which will stop code execution until a value is entered.
- Added a default parameter to the realtime() command that returns realtime(1)+0.001*realtime(2).
- Updated various pickoptions to use the TaskSequence and TaskExecuter APIs.
- Added tutorials for the Statistics Collector.
- Fixed some issues with the importtable() command.
AGV
- Added new Train functionality.
- Added offset travel functionality to the AGV network.
- Added a time-based trailing option.
- Added the routing drawing feature to a right click option.
- Updated Quick Properties' apply to all selected objects functionality to work with AGV objects.
- Made arrows bigger.
- Fixed several spinners in Quick Properties not applying immediately.
- Changed behavior for when a TaskExecuter is connected to an AGV network, and is set to use the navigator for its offset travel. Previously, the navigator was hard-coded to find the closest control point. Now, you instead need to add an OnAGVOffsetTravel trigger to the navigator, wherein you can direct the AGV how to offset.
People
- Added clipboard, test tube, and pill bottle flow items.
- Added a Max Speed property to Equipment objects.
- Updated Transport and Equipment objects to do low priority returns.
- Added the ability to install instanced People flows.
- Updated the LocationStaytimeHistory chart to handle people entering and exiting transports inside a location.
Process Flow
- Added an AGV travel activity.
- Updated the Sink to notify parent tokens on a Run Sub Flow activity that the child token finished the subflow.
- Updated the Wait for Event and Event-triggered Source activities to be able to display more than one link at a time.
- Updated the sampler for Universal Edit fields to display process flow variables and current labels when sampling white space.
- Added a pop-out library for choosing the shape of Container objects.
- Added a pop-out library for choosing the type of travel activity.
A*
- Updated the Heat Map to use a Color Pallete.
