vinom5292 avatar image
vinom5292 asked vinom5292 commented
subtract the Two Rows of same column in statistics Collector/Calculated Table
I have created a statistic collector in which I have column called as "OK TRAYS CUMULATIVE". This column stores the cumulative input to the Sink 1 on hourly bases.
But at the same time, I wish to subtract the Row Values of this column and create a new column.
I tried using Calculated Table, but unfortunately it offers only column to column subtraction.
Example = 361 - 179 = 182 and so on..
Can you please help me understand the way to subtract the values of the row in the same coloumn?Final Dashboard.fsm
Thanks,
vinom
FlexSim 24.1.1
statistic collectorcalculated tablesubstraction
final-dashboard.fsm (41.6 KiB)
Felix Möhlmann answered vinom5292 commented
You can add an extra column to the statistics collector that stores the difference between the cumulative value of the current and previous row.
final-dashboard_1.fsm
final-dashboard-1.fsm (636.1 KiB)
vinom5292 avatar image vinom5292 commented ·
Thank you so much Felix!
