Borja Lorenzo avatar image
Borja Lorenzo asked Borja Lorenzo commented
How to use calculate table from statistic collector
Hello everyone
In the attached model, I want to be able to calculate the difference between the end time of the last task and the start time of the first task in a 'Calculated Table.' Ideally, I would like to use this value to display it in a table chart on the dashboard.
Could you help me configure it?"
Thank you in advance.
Simplificación Statistic Collector from List 250113.fsm
FlexSim 24.1.1
statistic collectorcalculated tablesql queries
1 Like"
Felix Möhlmann answered Borja Lorenzo commented
Assuming that the value in the last row will always the highest the query would just be
SELECT MAX(Tiempo_Final) - MIN(Tiempo_Inicial) AS EnterColumnNameHere FROM Tiempo_Produccion
(Enable direct editing on the "Calculations" tab of the Calculated Table to be able to enter this manually and set the Update Mode to "Always")
· 3
Borja Lorenzo avatar image Borja Lorenzo commented ·
Thanks a lot
It works like a charm
Adjunto el archivo resuelto.
Simplificación Statistic Collector from List 250113_1.fsm
Jason Lightfoot avatar image Jason Lightfoot ♦♦ commented ·
Another answer to a duplicate question here.
Borja Lorenzo avatar image Borja Lorenzo Jason Lightfoot ♦♦ commented ·
