Rack 1 Example.fsmI need to let ASRS vehicle 1 put 2 boxes at same time in rack from conveyor 1,
and deliver 2 boxes at same time from rack to Conveyor 2
Move the exit transfer to the side of the conveyor and increase its size, so it can encompass more than one item.
Set the "Break To" option of the ASRS to only accept task sequences with the same load station.
Set the entry transfer to accept 2 (or more) incoming transports at a time.
If this does not suffice to achieve the desired behaviour, use Process Flow to control the ASRS.
Thank you now vehicle get 2 items but we need to place both item side by side currently it pick second item vertically. Required following:
You'll have to edit the tree of the ASRS to change the stacking. See the linked post for more information.
https://answers.flexsim.com/articles/148707/changing-task-executer-stacking-rules.html
14 People are following this question.
