Hi! I am trying to simulate a piping production process. A pipe (Spool ID) is connected to a job number. The job number represents one long pipe and Spool IDs with same job number all are sawed from that pipe. For the simulation I want to combine all the pipes with the same job number and than separate them again before they go in the production proces.
How can I pull and combine the SpoolIDs with the same job number?
In the example I just set the combiner on 5 but the amount of SpoolIDs with the same job number can vary. The table with the SpoolIDs and job number is the input for the source.
Thank you in advance for your help!
