Lucas Klein avatar image
1 Like"
Lucas Klein posted
RailWorks 2023 available
RailWorks 23.0.1 is now available ( 24 January 2023). This version of RailWorks is intended for use with FlexSim 2023.
All versions can be found in the Downloads section of your FlexSim account on the 3rd party modules tab. Please do not hesitate to report any bugs, usability improvements and feature requests to dev@flexsimbrasil.com.br
About RailWorks
The FlexSim Brasil RailWorks module consists of premade custom objects, designed to represent a real environment for the Rail problem modeling, with less configuration. Our approach is to unite 3D modeling with the Process Flow functionality, allowing object configuration and visualization through the native 3D FlexSim solution, and the rail system events to be triggered by the Process Flow, using not only defaults FlexSim Process Flow activities, but also new ones developed by our team.
For any questions, please email dev@flexsimbrasil.com.br
Release Notes
The following is a list of features and fixes that have been included in the latest RailWorks releases.
RailWorks 23.0.1 (24 January 2023)
  • Release for FlexSim 2023.0
RailWorks 22.2.3 (24 January 2023)
  • Bug Fix: Fixed various bugs affecting the locomotive movement.
  • Feature: Added automatic train detection and anticipation of movement.
  • Feature: Added a wait logic on locomotive to continue with movement when rail is not on use.RailWorks 21.2.4
  • Feature: Added GIS Portal object for integration with GIS Map.
  • Release for FlexSim 2022 Update 2
  • All bug fixes in RailWorks 21.2.4 below.
RailWorks 22.2.2 (12 December 2022)
RailWorks 22.2.1 (25 November 2022)
  • Bug Fix: Fixed various bugs affecting the definition of traveling routes
  • Bug Fix: Fixed various bugs affecting the locomotive and wagon movement amongst the rail tracks
  • Bug Fix: Fixed a bug affecting the usage of multiple locomotives at same railway
  • Bug Fix: Fixed a bug affecting the offset distance in Control Points
  • Bug Fix: Fixed a bug affecting the Decouple activity and Couple by another Locomotive
  • Retroative Release: New versions released with bugs fixed from 2021.2 to 2022.2
  • All bug fixes in RailWorks 21.2.2 below.
RailWorks 22.1.4 (24 January 2023)
RailWorks 22.1.3 (12 December 2022)
RailWorks 22.1.2 (23 November 2022)
RailWorks 22.1.1 (26 July 2022)
  • Release for FlexSim 2022 Update 1
  • Refactor: Changed the model limit control and system functionality
  • Feature: Added the PreCreate activity in ProcessFlow
  • Bug Fix: Fixed various bugs affecting the locomotive and wagon movement.
  • Bug Fix: Fixed a bug affecting the model limit creating new models.
  • Bug Fix: Fixed a bug affecting the model limit window with multiple modules installed.
  • All bug fixes in RailWorks 21.2.1 below.
RailWorks 22.0.4 (24 January 2023)
RailWorks 22.0.3 (12 December 2022)
RailWorks 22.0.2 (23 November 2022)
RailWorks 22.0.1 (26 July 2022)
  • Refactor: Changed the way that Rails can be resized and moved.
  • Feature: Added the RailWorks manual to FlexSim.
  • Feature: Added travel offset to the MoveTrain activity.
  • Feature: Added speed profiles to the Locomotive. That means that you can now set the speed of a Locomotive based upon if it is coupled to a Wagon or not.
  • Feature: Added acceleration and deceleration of locomotives.
  • Feature: Added RailwayTimetable, providing observability for the model as it saves every important event in RailWorks, like the time when a locomotive arrived at a station, as an example.
  • Feature: Added a new model to the Stations: Fuel Station.
  • Feature: Added a new model to the Stations: Flow Station.
  • Feature: Integration with FloWorks.
  • Feature: Added loading modes to thee LoadWagon activity.
  • Bug Fix: Fixed a bug affecting the load and unload actions.
  • Bug Fix: Fixed a bug affecting the Experimenter.
product announcementrailworks
lucas.klein contributed to this article
