RailWorks 22.0.0 is now available ( 25 July 2022). This version of RailWorks is intended for use with FlexSim 2022.
All versions can be found in the Downloads section of your FlexSim account on the 3rd party modules tab. Please do not hesitate to report any bugs, usability improvements and feature requests to developmentbrflexsim@flexsimbrasil.com.br
About RailWorks
The FlexSim Brasil RailWorks module consists of premade custom objects, designed to represent a real environment for the Rail problem modeling, with less configuration. Our approach is to unite 3D modeling with the Process Flow functionality, allowing object configuration and visualization through the native 3D FlexSim solution, and the rail system events to be triggered by the Process Flow, using not only defaults FlexSim Process Flow activities, but also new ones developed by our team.
For any questions, please email developmentbrflexsim@flexsimbrasil.com.br
Release notes
RailWorks 22.0.0
- Release for FlexSim 2022
- Refactor: Changed the way that Rails can be resized and moved.
- Feature: Added the RailWorks manual to FlexSim.
- Feature: Added travel offset to the MoveTrain activity.
- Feature: Added speed profiles to the Locomotive. That means that you can now set the speed of a Locomotive based upon if it is coupled to a Wagon or not.
- Feature: Added acceleration and deceleration of locomotives.
- Feature: Added RailwayTimetable, providing observability for the model as it saves every important event in RailWorks, like the time when a locomotive arrived at a station, as an example.
- Feature: Added a new model to the Stations: Fuel Station.
- Feature: Added a new model to the Stations: Flow Station.
- Feature: Integration with FloWorks.
- Feature: Added loading modes to thee LoadWagon activity.
- Bug Fix: Fixed various bugs affecting the locomotive movement.
- Bug Fix: Fixed a bug affecting the load and unload actions.
- Bug Fix: Fixed a bug affecting the Experimenter.
RailWorks 21.2.0
- Release for FlexSim 2021 Update 2
- Feature: Added a new routing algorithm option, focused on preventing train collisions (Requires Python installed).
- Bug Fix: Fixed a bug in the model limit.
RailWorks 21.1.0
- Release for FlexSim 2021 Update 1
- Feature: Added trigger - onCreate - to the SourceTrain object.
- Feature: Added triggers - onEntry, onExit - to the Rail object.
- Feature: Added triggers - onFuel, onLoad, onUnload - to the Station object.
- Feature: Added triggers - onLoad, onUnload - to the Crane object.
- Feature: Added trigger - onArrival - to the RailControlPoint object.
- Feature: Added tank wagon 3D Model option to the Wagon Object.
- Feature: Added custom dashboards to the module.
- Feature: Added auto-connect to SourceTrain to connect with the nearest ConnectPoint.
- Feature: Added the possibility to keep the FlowItems or create new ones when loading and unloading.
- Feature: Added the possibility to load FlowItems fractionally or discretely.
- Bug Fix: Fixed bugs on train movement.
- Bug Fix: Fixed bug on entry of task executer as flow item in Station.
- Bug Fix: Fixed a bug in the RailControlPoint.
- Refactor: Changed functionality of Rail's Connect Points.
- Style: Changed RailSystem model.
- Style: Added a new model to the Wagon Object: Gas Tank Wagon.
