Marian Cretu avatar image
Marian Cretu asked Marian Cretu edited
Forklift backing up on a specific area ?
Hello all,
Is it possible to make a transporter stop rotating if it goes backwards ?
For example if a transporter enters a very narrow corridor of the building and wants to reverse directio it should go backwards and not rotate then go forward.
Is it possible to make this work on specific areas of the warehouse defined by a plane for example?
Thank you.
FlexSim 20.1.0
transporterflexsim 20.1.0
Jason Lightfoot avatar image
1 Like"
Jason Lightfoot answered Marian Cretu edited
You can try setting the transporter flip threshold to lower value - it should work for some travel sceanrios. You may need to be on a network, or issue a travel relative task to move straight back before issuing the main travel task. If I get time I'll try this and post an example.
Marian Cretu avatar image Marian Cretu commented ·
It works perfect with the flip threshold! No network needed. Thank you so much.
