Fiorenzo A avatar image
Fiorenzo A asked anthony.johnson commented
Can I hide some Astar divider in a model?
I have this problem. I have a model where there are some divider with z coordinate = 0 and other divider with z coordinate = 5. Is there a way or a command with which I can hide only some of them, for example those with z coordinate = 0?
Can you halp me?
Thanks in advance.
FlexSim 20.2.1
astarflexsim 20.2.1dividerhide
Phil BoBo avatar image
2 Likes"
Phil BoBo answered anthony.johnson commented
Put the dividers you want to hide into a visual tool. Then hide the contents of the visual tool.
hide_astar_dividers.fsm
If you then want to programmatically hide and show them, use the switch_hidecontents() command.
· 2
Fiorenzo A avatar image Fiorenzo A commented ·
Great! thank you!
I have another question. Can I do the same also for the Astar Grid at the same z? In this case doesn't exist the treenode object to shift in the visual tool. Do you have any idea?
@Phil BoBo
Phil BoBo avatar image Phil BoBo ♦♦ Fiorenzo A commented ·
The grids are stored as variables in the AStarNavigator object itself. You can hide or show the grid bounds on the Visual tab of the A* Navigator's Properties window. You can't hide each grid's bounds individually.
Jason Lightfoot avatar image
Jason Lightfoot answered Jason Lightfoot edited
Not that I can see - if you'd like this feature then suggest it here on the forum using "Post an Idea" or mail it in to dev@flexsim.com
