Buenas tardes quiero abrir una simulacion FlexSim 20.1.1 pero no me es compatible con la version 20.0.8 y no encuentro el link de descarga de la version FlexSim 20.1.1, agradezco me puedan colaborar mi correo es angie.marisol.c@gmail.com
Translation via translate.google.com:
How can I see a FlexSim 20.1.1 simulation in FlexSim 20.0.8
Good afternoon I want to open a FlexSim 20.1.1 simulation but it is not compatible with version 20.0.8 and I cannot find the download link for the FlexSim 20.1.1 version, I thank you for helping me.
Hi @Angie Marisol CC, was my answer helpful? If so, please click the red "Accept" button on my answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
FlexSim models saved in a newer version cannot be opened in an older version of the software.
As new features are added to FlexSim, data structures and other background changes introduce incompatibilities with older versions of FlexSim that were not programmed to handle those changes.
Only the latest bugfix release of each feature branch is available for download from account.flexsim.com, and only from a licensed FlexSim Account.
Your requested version 20.1.1 is superseded by the latest 20.1 bugfix release, 20.1.3, which is available for download from a licensed FlexSim Account. Follow instructions here to see the "more versions" button and download the correct version of FlexSim.
Also, newer versions of FlexSim can open models built in an older version. Once saved in a newer version, however, the model files will have been updated for use only in that version of FlexSim, or later. This means that you can also open your 20.1 model in our latest release, 20.2, which is currently available for download even from guest accounts. The model will upgrade for use in the latest software version, and if saved for 20.2, the model file will no longer be compatible with 20.1. Be sure to save the upgraded model under a new filename if you need to keep it for compatibility with 20.1.
13 People are following this question.
