Haggai N2 avatar image
Haggai N2 asked Jacob Gillespie edited
Flexsim Texture
1.png2.pngHi, I just recently got into Flexsim. My problem is after importing autocad drawing into the flexsim, nothing shows up , just a blank background.
Im currently using the free version and i cant upload my autocad file as its too big.
FlexSim 19.1.0
autocad background
· 6
David Seo avatar image David Seo commented ·
@Haggai N2
Though you use FlexSim Express version(free license), you can import AutoCAD dwg as background. First try to import the default AutoCAD file in your installed FlexSim provided.
The file of 'Er_Small.dwg' name exist in your flexsim directory.
And next, make you a reference in the flexsim manual (Help).
Your autoCAD dwg file has many invalid entities of AutoCAD and they make importing result trouble. If you will upload your dwg file, anyone can help you quickly.
Haggai N2 avatar image Haggai N2 David Seo commented ·
@Seung Yong Seo I am unable to upload the AutoCAD drawing on flexsim due to the file being more than 25mb but i have cometest-drawing.dwg out with a much-simplified version of it.
I have used 'Er_Small.dwg' and it worked well.
test-drawing.dwg (31.7 KiB)
David Seo avatar image David Seo Haggai N2 commented ·
@Haggai N2
After you save it as AutoCAD 2012 version and then try to import it again.
I can't open your file using my autocad 2012 version.
Haggai N2 avatar image Haggai N2 commented ·
@Seung Yong Seo
I'm using a student version of it so i cant download AutoCAD 2012 version. I have uploaded my files into google drive, i hoped you would be able to access it.
https://drive.google.com/open?id=1topEbfJwUQAQy--komz4BVs4xhc_StgN
https://drive.google.com/open?id=14byOD1VYEiGjIYWzYtSBJgMquPeYj9no
Haggai N2 avatar image Haggai N2 Haggai N2 commented ·
@Seung Yong Seo, I am a total beginner at flexsim and autoCAD so i despartley needing help in this.
@Haggai N2
I also have only 2012 autocad and so I can't support as you want. I introduce your region Singapore distributer David Chan '+65 62089575 info@advent2labs.com'.
Please make him know your issue.
Jacob Gillespie avatar image
Jacob Gillespie answered Jacob Gillespie edited
I was able to load the dwg file that you attached. To see it you need to zoom out.
Attached is a model with the view zoomed out so you can see it.
cad-model.fsm
cad-model.fsm (42.1 KiB)
