User commands and User Events can both be added to the User library, what about global variables? Is it possible to add a global variable to the User library as a auto-install component?
This is not currently a supported feature. Feel free to create an idea or submit a dev request to dev@flexsim.com. See How do I submit feature requests or bug reports?
If you're willing to put in a little work you could implement this functionality in your own user library by creating a user library object with a dropscript node that creates a global variable through code. You can read about how to do that here, as detailed here: https://docs.flexsim.com/en/19.1/Reference/DeveloperAdvancedUser/CustomLibraries/
11 People are following this question.
