Lukas Lu avatar image
Lukas Lu asked Osama A6 commented
Use decide to make "AGV" charge
So im not using the AGV processflow template but i would still like to "charge" the AGV(just make it stand still for a few minutes in a predetermined spot).
I tried to create labels on the agv with the total time it has been working and the time of the last charge. So when the decide came it could compare and if it the difference was bigger than 100 it would go "charge".
Could this work? I didn't know if i could do it like the drink fountain in the tutorials because i use 1 token that loops.
agv-charge-test.fsm
FlexSim 18.2.2
agvdecide
agv-charge-test.fsm (44.1 KiB)
gilbert jerald avatar image
gilbert jerald answered Lukas Lu commented
@Lukas Lu
Hi.
The problem in your model is you have made mistake in getting the label name in the process flow, in Decided activity and I have made some minor changes in your model. that works now and I have attached it for your reference.
support-agv-battery-charging.fsm
Lukas Lu avatar image Lukas Lu commented ·
Thank you!
Karuppasamy Pitchai avatar image
1 Like"
Karuppasamy Pitchai answered Osama A6 commented
@Lukas Lu I have modified your process flow based on your requirements. Here is the updated model.agv-charge-test.fsm
agv-charge-test.fsm (40.6 KiB)
· 2
Thank you!
Osama A6 avatar image Osama A6 Lukas Lu commented ·
Where is the SOC level in this model?
