tong avatar image
tong asked tong commented
Process flow two token Synchronize
Hello, I have a question about a Synchronize Activity. Looking the follow diagram, A token through a Split Activity creates two independence token . Then the two tokens through Split Activity create two independence tokens each other. In the end, I want to choose two tokens from the four tokens to Synchronize. Result, the two token is unable to cooperate. How to implement this function ? Looking forward to your reply. @phil.bobo
FlexSim 18.1.0
process flow two token synchronize
jing.c avatar image
1 Like"
jing.c answered tong commented
hi @tong
Your problem is not to distinguish different splitID from different "Split" activity.
You should specified each "Split" activity with different splitID, or "synchronize" activity can not figure out which split activity this token from.
The attached modified model is below, and hope it helps~
two-token-synchronizembychjv181.fsm
tong avatar image tong commented ·
Thanks very much !@jing.chen
