Vanessa B3 avatar image
Vanessa B3 asked Vanessa B3 commented
Pull Using Demand Statistical Distribution
Hi everyone !
I've created the following model to represent a base stock model, where the reorder point is 66 and the economic lot size is 228, represented by the batch of the first queue. Now, I'd like that the second processor (or a sink) pulled items from the second queue following the statistical distribution normal (6,0.5,0) that represents its daily demand. As in one day, the processor should pull an average of 6 items, varying accordingly to the statistical distribution.
Is there some way to do this?
Thanks !
modelo-base-62.fsm
Choose One
pull strategy
modelo-base-62.fsm (18.5 KiB)
Michael Machado avatar image
Michael Machado answered Vanessa B3 commented
Are you using the Express Version or Educational/Enterprise/Student version of the software? If you are using the Express Version, the random streams is blocked, so, even if you use any distribution, it will behavior like a deterministic model. Let me know.
Vanessa B3 avatar image Vanessa B3 commented ·
@Michael Machado
Right now I'm using a student version of the software!
1 Like"
Michael Machado answered Michael Machado edited
Please, see the attached model and follow the instruction in the image below. Click in the icon inside the red circle and see how I customized the logic in the field 'Pull Requirement'. If I right understood your question, you can use the model to move foward. Also, if you need support into portuguese, e-mail suporte@flexsimbrasil.com.br.
8528-modelo-base-62bymm.fsm
· 2
@Michael Machado
I don't know why but I'm having trouble opening your model. When I try to open it, FlexSim stops working.
Could you share the custom logic you created here?
Thanks for the support !!
Michael Machado avatar image Michael Machado commented ·
Sorry, attached is the model in the version 2017 Update 1. 8528-modelo-base-62bymm.fsm
Vanessa B3 answered
@Michael Machado
Thanks for your help! I've tested the model but it seems the processor is pulling items according to the process time rather than the pull strategy itself.
Also, I'd like that the quantity of items pulled (and not the process time) followed a normal distribution.
