Sean Goh avatar image
Sean Goh asked Ben Wilson edited
System Console Pop out problem when using Dashboard ?
1) Last few days, I keep getting System Console window pop out (refer to attached JPG files) when I open any existing and new models with Dashboard display. I was using Flexsim Version 17.0.1 then. It seems to happen after I try saving some Dashboards to HTML files.
2.After I upgrade to Flexsim Version 17.0.3, it still has the System console pop out (blank window) whenever I open any model files with Dashboard. If I close the System console and run the model, some of the Dashboard display cannot be seen. I need to reopen the System console, close it again and then the dashboard display can be seen.
3.Now whenever I add Dashboard when creating any new model, the System console always pop out with message “exception: could not write html file”.
You can refer to attached sample “tryout.fsm” model which I created to experiment with this issue.
Please help advise on this problem and how to fix this ? Thanks!
@phil.bobo@flexsim.com
dashboard displaysystem consoleexport all dashboards to html
Phil BoBo avatar image
1 Like"
Phil BoBo answered Ben Wilson edited
The "could not write to html file" exception is usually related to permissions on the C:\ProgramData\Flexsim\FlexSim17.0\help directory. See exception: Could not write html file (User Manual) - FlexSim Community Forum
Sean Goh avatar image Sean Goh commented ·
Thank you very much for the advice. Have enabled the control permissions on the C:\ProgramData\Flexsim\FlexSim17.0\help directory and it is working fine now without the exception message.
