Tomi Kosunen avatar image
Tomi Kosunen asked Tomi Kosunen commented
Reversing TaskExecuter
What would be the easiest and most flexible way to model reversing TaskExecuter? In my model, the TE moves pallets into a tunnel and returns backward (as there is no space to rotate).
"Rotate while traveling" selection does not solve the problem because the TE must follow curved path while reversing. Should I switch the TE geometry between "reversing TE" and "forward TE" depending on the moving direction? That sound a little hazard, doesn't it?
FlexSim 17.0.1
reversing taskexecuter
Steven Hamoen avatar image
4 Likes"
Steven Hamoen answered
@tomi.kosunen Try to play around with the "Flip threshold". Use the triggers on the path network node to set the "Flip threshold" correctly.
Zan Xueyan avatar image
Zan Xueyan Suspended answered Tomi Kosunen commented
You can set "Flip threshold" value is 1~179,it's OK!
Tomi Kosunen avatar image Tomi Kosunen commented ·
Thanks. I did play with the flip threshold and the result was good enough.
gilbert jerald avatar image
gilbert jerald answered Tomi Kosunen commented
@tomi.kosunen
I have read your question based on my understanding i have built a sample model and i have attach it for your reference . i don't know whether it is correct or not . have a look on it
Thank you
te.fsm
te.fsm (28.5 KiB)
Thanks Gilbert for your post. That doesn't exactly solve my problem. Your sample model demonstrates 1)"Rotate while traveling" selection which did not was the solution , 2) TE traveling free without node network which does not solve the problem either and 3) TE traveling always forward. So I'm still on need for some advice.
