I would like to sort the data in a Map class by key, so I converted the Map to an Array and use the sort() method of Array, but it hangs in 2024 but ran without any problems in 2025. What is the difference in this behavior?
For each model, when you run the script after fast forwarding, it will hang in 24.0.9 version, but there will be no problem in 25.0.6 version.
https://answers.flexsim.com/articles/164649/heatmap-anything.html
Thanks in advance.
