Sebastian Hemmann avatar image
1 Like"
Sebastian Hemmann asked Sebastian Hemmann edited
Strange behavior in using AStar bridge
It seems that using a bridge in AStar makes problems with routing the operators or other Task Executers.
The operator stops at the end of the bridge object. If 2 operators are on the path the same time, they are jumping around.
I attache the model but only used default options so far.
AStar_Bridge_Problem_FlexSim25.1_SH.fsm
FlexSim 25.1.1
astarbridge
