chiang avatar image
chiang asked chiang commented
Changing direction adds seconds
I want to create a similar model. When a car passes through the control area, if it is in the same direction as the previous car, it can pass directly, but if it is in a different direction from the previous car, it needs to wait for a fixed number of seconds! How should I design it?change.fsm
FlexSim 25.0.0
agvconditional decide
change.fsm (36.7 KiB)
Steven Hamoen avatar image
Steven Hamoen answered chiang commented
@chiang you can put a label somewhere or use a global variable that you set when a vehicle passes a control point. At the same time you send your vehicles always to a controlpoint just before the crossing and there check what the previous crossing was act upon the check and on continue set the flag again
chiang avatar image chiang commented ·
sir sorry !can u have some example ? i need to learn about that
