Francis Yang avatar image
Francis Yang asked Francis Yang commented
Having issue with change color for created flow item by label values
Relatively new to the software but I've tried several ways of setting this up. The situation is:
I'm using the process flow token to create objects in 3D model, one is film and another is bilayer tape. For bilayer tape I'm assigning the label value as binary (0&1) in alternative order, which I fortunately found the code from another post. But then I'm unable to set two colors by the label values for created objects. Could someone please help me look at whether there is issue with label setting or change visual setting? Also is there an easier way to set up alternating binary label values when creating objects?
On the other hand, I applied Round Robin to send created objects from Film Storage to Film WIP Cart 1&2, how can I customize the batch size to send desired qty of objects to alternating locations? (I tried perform batching from the source queue, doesn't work as the way I expected)
FlexSim Q&A flow item color by case.fsm
FlexSim 25.0.4
process flowchange visual
David Seo avatar image
David Seo answered Francis Yang commented
flexsim-qa-flow-item-color-by-case_SFK.fsm
I fix your model. You should fix the label name field.
Francis Yang avatar image Francis Yang commented ·
I see, thank you so much for fixing the issue
Any advice on my further questions regarding binary label value and Round Robin setup?
