model.fsmHow to make the task executers transport a specific amount of flowitems from each queue
I'd suggest to use Process Flow and make each processor push its item to a different partition. That makes it easy so pull a specific number from each processor and also to know when all items have arrived in the queue.
Thank you for your help, I would like to withdraw a quantity at a time. The operator goes to the queue and withdraws 5 items at a time.
The operator needs to have a sufficient capacity. Then you can adjust the Process Flow logic so it pulls and sends multiple items at a time.
11 People are following this question.
