Yuito.Y avatar image
Yuito.Y asked Yuito.Y commented
The event times for unloading are different
The start time of the event differs depending on whether the unload destination is a 3D object or a FlowItem.
Events such as the road before that happen at the same time.
What is the reason for this?
Is there also a possibility of a bug?
You can change the destination by modifying the value of the parameter.
Best regards.
Unload_EventTIme_diff.fsm
FlexSim 24.0.9
unloadevent log
Felix Möhlmann answered Yuito.Y commented
The unload task first calls the "placeoffset" of the destination object to know where the item should be placed when unloading. If not specified otherwise the TE will then travel to that location. At that point the unload time starts. When it elapses the item is placed in the destination object.
The offset travel distance to the queue and pallet are different. Why would the unload happen at the same time under these conditions?
Yuito.Y avatar image Yuito.Y commented ·
I asked a question because the unload times were different, even though the coordinates were the same, when I replaced the temporary holding place for items from an object to a flow item.
Since we were able to identify the cause of the issue, it's fine to close it.
Thank you.
