yexioamu avatar image
yexioamu asked yexioamu commented
Why the OnPartitionContentChange does not work?
I create a list and push two partition values to the list, then pull from the list by one patition, i use the Event-triggered source to listen the OnPartitionContentChange event, i hope the event be fired when the list partition decrease to exact value, but it did't work, no token be triggered.
Can anyone help me?
OnPartitionContentChange.fsm
FlexSim 21.2.4
listevent triggered sourceonpartitioncontentchange
Felix Möhlmann answered yexioamu commented
The object you listen to must be the global list from the tool box instead of the list activity.
· 6
yexioamu avatar image yexioamu commented ·
I modify the listen object to the list from the tool box, but it does not work too.
Felix Möhlmann avatar image Felix Möhlmann yexioamu commented ·
Right, sorry, I forgot to mention that the GlobalLists node must be above the ProcessFlow node in the toolbox as well. (Bit of a weird requirement, I know.)
yexioamu avatar image yexioamu Felix Möhlmann commented ·
Although a bit strange, it actually works.
thank you!
