juliategami avatar image
juliategami asked juliategami edited
Dashboard Staytime MultiProcessor
Hello, how are you? I hope you are well.
In my simulation model, I have a multiprocessor that has two different processes, with different process times, and I would like to graphically visualize the dwell time per hour of each one separately. Is this possible? If so, could you give me a practical example, please?
Thanks in advance!
FlexSim 24.2.1
dashboardsmultiprocessorstaytimes
João Dias avatar image
João Dias answered juliategami edited
Hello Julia! How are you?
Yes, it is definitely possible to achieve this analysis, although it requires a bit more effort when it comes to data collection. Let me give you a few practical suggestions:
One approach would be to monitor the equipment states. Every time an item enters the first process, you can assign it a specific state, and then assign a different state when it moves to the second process. This way, you can later create a dwell time graph (staytime) separately for each process based on these states.
Another alternative, which might simplify both data collection and analysis, would be to replace the multiprocessor with two independent processors. This would allow you to obtain separate statistics for each process directly, making it easier to build the desired graph.
Additionally, if you are comfortable with the tool and use programming, there is a similar question available at this link [https://answers.flexsim.com/questions/25391/how-to-get-the-total-stay-time-for-a-flow-item-thr.html], which presents a good solution that might help you as well.
Feel free to reach out if you need more details or even a practical example, I’ll be happy to assist you!
juliategami avatar image juliategami commented ·
Hi @João Dias, I'm fine, and you? I hope you're doing well
I'm having trouble replicating the code used in the example you suggested. I have a simple model attached, where I have two lines, a multiprocessor with process 1 and process 2, and another with a processor. For the line with the processor, I was able to analyze the data with the standard dashboards, and I would like to have the same visualization for the multiprocessor. Could you help me with an example based on this simulation model, please?
I would like to thank you very much for your help and attention.
teste-script.fsm (33.8 KiB)
