Amélie avatar image
Amélie asked Felix Möhlmann commented
Set Location for different Items in a combiner
I have already see this answer but I try it and it doesn't work with my process
https://answers.flexsim.com/questions/28916/set-location-for-different-items-in-a-combiner.html
This is my process :
I would like to place the large boxes on top of the first shelf and the small ones on the second and third shelves. Is it possible to define a specific location for each item in a way other than the 2016 answer?
Question Combiner.fsm
Thanks and best regards,
FlexSim 25.0.3
combiner
Felix Möhlmann answered Felix Möhlmann commented
For container items, you can define which packing logic they use in the FlowItemBin. You can also define your own packing logic there.
If the items always enter in the same order you could use the item rank to decide where to place them inside the shelf. You could also first check the dimensions of the item and decide based on that.
question-combiner_1.fsm
· 2
Amélie avatar image Amélie commented ·
Thanks for your answer but I didn't see in Properties the FlowItem (Picture below)1743502076143.png
Felix Möhlmann avatar image Felix Möhlmann Amélie commented ·
That panel only shows up for container flow items.
