Elax Kot avatar image
Elax Kot asked Elax Kot commented
Error when using FlexSim WebServer
Hi all, I was trying to use FlexSim Webserver but when trying to run the models, the command prompt would say that it would timeout. I've added a huge timeout in the settings and double checked the settings and it seems like both the model files and the flexsim application can be detected.
I'm using Flexsim 23.2 with Webserver 24.2. I'm unable to find any older version to use with it. I would like to ask if there is any resource to look at.
FlexSim 23.2.3
flexsim webserver
Joerg Vogel avatar image
Joerg Vogel answered Elax Kot commented
You can load older versions in an user account, if you have access to a maintained license. There is a button to show more versions.
· 3
Elax Kot avatar image Elax Kot commented ·
The license is from a license server so my account is unlicensed. The option is not available for me. Would it be possible for me to get a copy of the older version of the webserver then?
Joerg Vogel avatar image Joerg Vogel Elax Kot commented ·
@Elax Kot, then you can contact your adminstration of this license server.
Elax Kot avatar image Elax Kot Joerg Vogel commented ·
Got it! Thanks!
For anyone referring to this in the future, you can contact your distributor to get the archived versions. Also, Flexsim 23.2 would work with 22.2 WebServer.
