Flavio Lopes avatar image
Flavio Lopes asked Felix Möhlmann commented
Using Process Flow to Create Objects in different locations
I need to create a specific number of boxes while maintaining a consistent distance between them (like the Picture below). I attempted to use the 'Move Object' option in the Process Flow, but I couldn't figure out how to relocate them to different positions
FlexSim 25.0.4
processs flowmoveobject
example-1.fsm (31.6 KiB)
Nil Ns avatar image
Nil Ns answered Felix Möhlmann commented
Hello Flavio,
Instead of using the "Move Object" option in the Process Flow, I suggest you try using the "Change Visual" feature. With "Change Visual," you can modify the location or position of an object without actually moving it from one entity to another.
The "Move" option is ideal when you want to relocate an object between different entities—for example, moving a box from a rack to a cart. However, in your case, since the box remains in the model and only its position changes, "Change Visual" is the most appropriate solution.
· 2
Flavio Lopes avatar image Flavio Lopes commented ·
Hello Nil,
I see it that in the Change Visual we have the option to change the object location, but how can I reallocate the objects to differente locations? Like a showed in the image.
Because I only find the option to send all objects to the same coordinates
Felix Möhlmann avatar image Felix Möhlmann Flavio Lopes commented ·
example-2.fsm
When creating multiple tokens in a Create Tokens or Run Sub Flow activity, you can use the creationRank variable to access the index of the created token. Based on that index you can calculate the coordinates where the item should be placed.
example-2.fsm (30.6 KiB)
