Nate avatar image
Nate asked Nate commented
Is Flexsim Down or technical issues?
I might be a little stressed, but I am using Flexsim for a critical project due in a little over two weeks. I was working on a model earlier today, and I went to load into the model about 5 hours later to work on it again and FlexSim isn't working properly. The Overall UI is terrible and it won't load the models I saved, making me wonder if it accidentally got deleted.
I get a system console the second I load in (shown below).
exception: FlexScript exception: Method find() called on node that does not exist at MAIN:/project/events/OnStartApp/read user prefs at line 17
exception: FlexScript exception: Invalid node passed to FlexSim::set at MAIN:/project/events/OnStartApp/initialize environment at line 45
exception: FlexScript exception: Invalid node passed to FlexSim::set at MAIN:/project/events/OnStartApp/initiate autosave at line 10
This to me seems like its not reading something, making it glitchy. I reinstalled FlexSim and it didn't resolve the issue. Any ideas?
FlexSim 25.0.4
display crashed
Matthew Gillespie avatar image
1 Like"
Matthew Gillespie answered Nate commented
It sounds like prefs.t is corrupted. Delete the prefs.t file for 25.0 (A new default one will be created when you open FlexSim again):
C:\Users\[user]\AppData\Roaming\FlexSim\FlexSim25.0\prefs.t
Nate avatar image Nate commented ·
That was it, Thank you!
