flexsimuser avatar image
flexsimuser asked Felix Möhlmann commented
Set the Crew Size by Shift and Area?
I am trying to build a model to easily change the crew size of each area and shift. What's the best way of doing this. My first thought was to build a dispatcher for each, but with 5 shifts and 15+areas, I was hoping there might be a better way that I am not thinking about. Any ideas?
Machinist Welder Inspector
Shift 1 10 8 5
Shift 2 7 3 3
FlexSim 25.0.3
operatortaskexecutorsshift schedule
Felix Möhlmann answered Felix Möhlmann commented
You could do something similar to this. With one group/dispatcher per area. If you can determine which shift is about to end/start based on the time of day in the model, then you could potentially build this into a single time table. But using one time table per shift might ultimately be quicker to set up.
Similarly, it would be possible to assign the roles from a global pool of operators, but that will likely bring other problems with it when the shift changes. Like a machinist who is currently busy becoming a welder. Keeping them in separate groups also makes collecting utilization statistics per area much easier.
· 8
flexsimuser avatar image flexsimuser commented ·
Thanks, but I don't believe this approach will work for my case.
Felix Möhlmann avatar image Felix Möhlmann flexsimuser commented ·
Can you provide some more detail on why it wouldn't work. That would make it easier to come up with other ideas that might better suit your needs.
flexsimuser avatar image flexsimuser flexsimuser commented ·
I am hoping to be able to quickly change the numbers in the table (or switch reference tables) to see the results of manipulating the crew size of the different shifts. Crew size by shift does not always decrease.
I don't see how this disqualifies the linked model as a possible solution? You can read the maximum value from the table and adjust the number of operators accordingly.
timetableswithtaskops-2.fsm
