David avatar image
David asked David commented
Destination based on token label
Hi everyone,
I'm trying to change destination of task executers based on token labels. Tokens have labels "Destination" with values NN3 or NN5 and based on these values I'm trying to navigate task executers to correspoding network nodes. But I'm having trouble with how to correctly inherit label value to destination field.
What should be the correct way to change destination based on label?
destination based on token label.fsm
FlexSim 24.2.2
taskexecutorslabel valuedestinationlabel destination
Krzysztof J avatar image
Krzysztof J answered David commented
In the second travel put:
Model.find(token.Destination)
Your label value is a string - destination should be a pointer.
David avatar image David commented ·
Thanks Krzysztof, it works.
