Hello team,
Box should move to other station when it is available.
Boxes should not accumulate between the stations
One box process on combiner and then transfer to other station if the station is available.
Thanks in advance
Hello team,
Thanks in advance
For the flow on the conveyors, use the Area Restriction options in the stations's triggers. To control the entry onto the conveyors, you can close the combiner's output after each exit and have it open again once the item resumes from the first station.
Thanks @Felix Möhlmann
If there is a station in between rework linked stations the logic is not working.
So either move that station back or decide on the rework on the previous station (Set Label option from OnProcessFinish trigger)
12 People are following this question.
