I have found that I cannot access a value of option-type paramters with flexscript ("Model.parameters.Parameter1"). I have checked that flexscript with braket works well (Model.parameters["Parameter1"].value). I attached the file.
Thank you.
Thank you.
Interesting. While the documentation states that both expressions are identical in behaviour, this apparently isn't true for the option type parameter.
The syntax with square brackets returns the rank of the currently chosen option. Whereas "Model.parameters.Parameter1" returns the value assigned to the currently active option.
I think it should be fixed because when I assign a value into the parameter, it chages chosen option, not assigned value. (Model.parameters.Parameter1 = 2)
There is also another issue with this feature. If one gets the "value", it returns the row of the option, not the content written in the right hand column. For instance, for Option3 the value would return 3 instead of 1. The same problem happens with list widgets on dashboards.
14 People are following this question.
