Olexii avatar image
Olexii asked Olexii commented
How to access utilization pie chart values via code?
Hello! I am trying to access "37.68%" value from within the code to later put it in a global table at a certain time. Is it possible? I've seen people access a different dashboard values via a tree, but I cannot find any tree variable for the pie chart that would reflect "37.68%". Thanks!
FlexSim 24.2.1
dashboards
Logan Gold avatar image
Logan Gold answered Olexii commented
Hey @Olexii, my understanding is the utilization displayed in the State Pie chart is calculated on-the-fly/continuously. I don't think it's stored anywhere in the tree. However, you can use the same command that the chart uses, called getstatetableutilization(), to get an Object's utilization, like this:
Object obj = Model.find("Processor1");
string stateTableName = "StateTable1";
return getstatetableutilization(Table(StateTableName), obj.stats.state());
You just need to make sure to reference the correct Object when using this command. Also, it needs to be referenced as an Object in order for the stats property to be accessed. If you have it as a treenode, you can always cast it as an Object with the as() command:
// Model.find() returns a treenode.
return getstatetableutilization(Table("StateTable1"), Model.find("Processor1").as(Object).stats.state());
Olexii avatar image Olexii commented ·
Good morning, Logan! Thanks for your suggestions, I will try them today.
This particular pie chart is for Operator's utilization, will that work the same way? Also, this pie chart is a Composite for multiple Ops, will I need to access each Op State Table and average?
