Victoria avatar image
Victoria asked Victoria commented
Error: Bad Task Sequence reference in finish task sequence activity
My tokens and associated items will move appropriately until the end of the IQ_Visual_Waf process flow activity. After completion, the tokens stay in the Finish Task Sequence activity and I get the error exception: Error: Bad Task Sequence reference in finish task sequence activity IQ_Visual_Waf/Finish TS in process flow "ProcessFlow".
Additionally, after 4 tokens build up in the Finish TS step, no more tokens move into the IQ_Visual_Waf process flow and the operator stops collecting boxes from the IncomingWafers rack.
FederalFactoryModel1.fsm
FlexSim 25.0.1
task sequenceprocessflow error
Emily Hardy avatar image
Emily Hardy answered Victoria commented
The issue is that you told the processor to use "QualityTech" as the operator for setup and for processing, and you told the processor that it could preempt and abort active tasks on the operator:
This is aborting the QualityTech's Task Sequence.
You already have the operator acquired and at the machine via process flow, so you don't need the "Use Operator" on the actual processor.
Victoria avatar image Victoria commented ·
Thank you!
