dantasvagner avatar image
dantasvagner asked Jeanette F commented
System Console Error Message
070125- MODELE V4.fsm
I am working on a warehouse model for order picking. After running the model for a few days, I have encountered some minor errors (displayed on the system console) related to the following find item/find slot operations:
-Concerned activities in the process flow:
-Error messages:
Le syntax seems correct for me. Do you have any suggestions on how to resolve this issue?
Please find the model attached.
Thank you in advance!
FlexSim 24.0.6
findslotfinditem
Hi @dantasvagner,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
dantasvagner answered Clair A commented
Hello Clair,
I have just updated the query ( with a single =) but the error message remains:
· 2
Clair A avatar image Clair A commented ·
Sorry, at first I had not seen that you attached the model. Your model is hard to debug because it's not repeatable. When I reset and run, the SqlQuery exception is not thrown at the same time as the previous run, even if Repeat Random Streams is activated. When trying to debug a model, the method is to add a stop time right before the exception is thrown, and then go the next events step by step. However as in your model the exception is thrown at different times for each run I can't apply this method.
On which object is the SKU label ?
On the pallets you have a label called SKUs, but there is no label called SKU.
