Jon Abbott avatar image
3 Likes"
Jon Abbott asked Trex-2 commented
Finding the nearest open slots to an item in a rack
Is there a way to use findSlot to identify open rack slots nearest in distance to an item that is already stored in a rack? Thanks in advance for your help.
FlexSim 20.0.5
rackflowitemfindslotflexsim 20.0.5nearest
Trex-2 avatar image Trex-2 commented ·
I have used the model find_nearest_slot_1.fsm it works really great but for one floor storage but when i use multiple floor storage in the model it does not work. attaching my model. can anyone help.find-nearest-slot-1_Updated.fsm
Phil BoBo avatar image
4 Likes"
Phil BoBo answered Trex-2 commented
@Jon Abbott
Here's an example using the Warehousing pick options in Process Flow.
find_nearest_slot.fsm
· 4
anthony.johnson avatar image anthony.johnson ♦♦ commented ·
Note this example will only compare locations within the same rack. If you want to compare locations across different racks, you need to use the Vec3.project() method to translate the location from the rack's local space to the model space.
4 Likes 4 ·
Phil BoBo avatar image Phil BoBo ♦♦ commented ·
For others that may look at this question/answer, here's another example that uses the feature of using multiple Queries in Find Slot. This example will try to avoid mixing slots with different types.
First, it looks for a slot that has an item that it matches.
Then it looks for the nearest empty slot.
Finally, it looks for the nearest slot with space regardless of what is in it.
Results in this:
Instead of this:
Trex-2 avatar image Trex-2 Phil BoBo ♦♦ commented ·
can we do it for particular rack or floor storage in model, can i know i query we need to put and where so we find the slot in that particular storage object
Jon Abbott avatar image Jon Abbott commented ·
This is great! Thanks @phil.bobo and @anthony.johnson for all of your help with this.
1 Like"
anthony.johnson answered
@Jon Abbott Here's sample code I executed in a script window:
Storage.Slot other = Model.find("Rack1").as(Storage.Object).getSlot(7, 4, 1);
return Storage.system.findSlot("ORDER BY (slot.location.project(slot.storageObject, model()) - $1.as(Storage.Slot).location.project($1.as(Storage.Slot).storageObject, model())).magnitude ASC", 0, other.as(treenode));
Or you can make a command that calculates the distance and call that from the query.
