Tushar H avatar image
Tushar H asked Tushar H commented
Coding Error
Hello team,
I am trying to learn coding so i tried one code
its working only for first cycle.
I want to do is it will run continuously its means first 5 boxes will come then input port will close for 100 seconds and again open for next 5 boxes but for next cycle its continuously open
please correct me by using coding only
thank you in advance
FlexSim 24.1.0
coding
Felix Möhlmann answered Tushar H commented
You are reading the input statistic of the queue which only ever increases (apart from being reset when a warmup time is set). You need a local counter, for example a label that you can reset back to 0 whenever the output gets closed.
I would also advice against using "await". It won't make a difference in this small example model. But it needs to store any variables from the code in a node so it can later resume the execution and is thus much slower than using messages or delayednodefunction(). With the latter you can call the same code again but pass in an additional parameter that changes what the code does. For starters, I would just use messages though.
· 5
Tushar H avatar image Tushar H commented ·
Hello ,
its working well but when i used two ports then its not coming as per counter
I have given counter 5 and coming 8 then and next cycle coming 7. can we fix this count for each cycle
trigger logic.fsm
trigger-logic.fsm (61.9 KiB)
Felix Möhlmann avatar image Felix Möhlmann Tushar H commented ·
Same issue as in your previous question. https://answers.flexsim.com/questions/175581/event-source-start-without-completing-task.html
You need to close the input when the final transport is planned, not when it finishes.
Tushar H avatar image Tushar H Felix Möhlmann commented ·
Can we do this in coding to close the input
