Hello All,
In this model I have given rack output schedule as per time and types, but I am unable to find where I did wrong logic.
forklift in not loading items.
Hello All,
The 'itemType' is an interval property of Flow Items (that is deprecated and shouldn't really be used anymore). In the creation trigger of the source you set this value to 1, 2 or 3 randomly. In the Pull from List the query states that this should be equal to the "itemType" label on the token. Which it can't be because those are either "A", "B" or "C".
The correct value to use in the pull query is the "Type" label on the item that is defined in the arrival schedule of the source.
And assigning colors based on a string label is easier though the usage of a color palette.
Just one thing I want to ask if I change rack slot assignment strategy to matching label then rack is not pulling items from source
11 People are following this question.
