Kadircan T avatar image
Kadircan T asked Kadircan T commented
Help with Sorting Boxes Based on Labels in Two Processors
In my model, I would like to split boxes from Processor3 into two separate queues based on their labels. Then, I need to further divide boxes from Processor2 into 4 separate queues, again based on their labels.
  • For Processor3, the label I want to use is the "mylabel3" column, which I defined in the "Edit Labels" section of the source.
  • For Processor4, I want it to consider the "route" column as the label for sorting.
I tried using triggers but couldn't make it work. Could you please help me with this issue? I’ve attached my model for reference.
Thank you!
sorting.fsm
FlexSim 24.2.2
sortingqueu
sorting.fsm (37.5 KiB)
Felix Möhlmann answered Kadircan T commented
Use "Port By Case" in the Send to Port field (and deactivate the Pull behaviour in the sort queues).
· 2
Joerg Vogel avatar image Joerg Vogel commented ·
Pull by matching with Name of Queue
comparing to a static string works, too - "A".
Kadircan T avatar image Kadircan T commented ·
Hi Felix,
Thank you so much for your help! Your solution worked perfectly, and I truly appreciate the time and effort you put into explaining it. I was struggling with this issue for a while, and your guidance made everything so much clearer.
Your expertise and willingness to assist are what make this community such a great place. Thanks again for your support!
