Unax Urrutia avatar image
Unax Urrutia asked Jason Lightfoot commented
RACKS CAPACITY
Is it possible to obtain the number of items could fit in the racks I have in the model?
FlexSim 23.2.3
racks
Jason Lightfoot avatar image
Jason Lightfoot answered Jason Lightfoot commented
Check the script used in the answer to this post, which will populate a table with each rack's capacity for each FlowItem you include in an array.
· 3
Unax Urrutia avatar image Unax Urrutia commented ·
Thanks for your answer @Jason Lightfoot
It is more interesting the way that is responded in your asnwer. In my case I have some slots divided by cases. Each case has a different size that is run in a Global Table.
Is it posible to have the answer of storage capacity in order to the size of the Global Table or the cases created in the source?
In case, I attach my model.
Thanks in advanced.
EIKA_Osoa_autosave.fsm
Hello @Jason Lightfoot
In order to this answer https://answers.flexsim.com/answers/146026/view.html
In my simulation case I don't know how to run the code
In my case I have 3 different size of items displayed in a Global Table
Therefore, I want to see capacity of racks in order to each Rack and for each size (in the entire rack the same size in all cases)
I dont't know if I have been clear and you could help me.
Thanks another time,
Regards,
Unax
Jason Lightfoot avatar image Jason Lightfoot ♦♦ Unax Urrutia commented ·
It looks like you only have 4 different sizes, so we can express the capacity in terms of those (eg. A, B, C, D):
Model attached where I created the flowitems BoxA-D to represent those sizes, and added the command 'generateRackCapacties' along with the script to use it:
Array flowitemnames=["BoxA","BoxB","BoxC","BoxD"];
generateRackCapacities(flowitemnames);
eika-osoa.fsm
eika-osoa.fsm (179.6 KiB)
Paula LG avatar image
1 Like"
Paula LG answered Paula LG edited
Hi Unax,
To do so, use the following script:
Storage.system.querySlots("").length
If you only want to count slots that meet a specific condition, write your desired query instead of the empty string.
I hope it helps!
Unax Urrutia answered Felix Möhlmann commented
Thanks for your answer Paula.
Where I have to put that script?
Sorry if it is so simple the question, I am starting with the software...
Felix Möhlmann avatar image Felix Möhlmann commented ·
You'd put that whereever you need to know the number of slots. If you just want to check this manually you could run it in a script console.
Note that this returns the number of slots. If a slot can fit more than one item you need to multiply the returned value by how many items can fit into a slot.
