is there a way to add pre-configured tables, lists and dashboards to a user library? By pre-configured, I refer to the structure (column/field names and expressions, overall layout, etc.) not the content.
Thank you.
Thank you.
You're basically looking for the same icon everywhere that indicates to add to the user library.
Here is the icon for the Global Tables:
And for lists it's at the bottom left of the of the properties:
thank you. I realized it when I found the post below (by chance, as explained below).
Thank you!
Ok, so I have found this link that might help other interested:
https://answers.flexsim.com/questions/164291/uploading-a-custom-library.html
The name of the question is not much telling, as the content is closer to the question posed above.
A suggestion is having this as part of the documentation:
https://docs.flexsim.com/en/23.0/Reference/DeveloperAdvancedUser/CustomLibraries/CustomLibraries.html
Thank you
15 People are following this question.
