SuhyeonK avatar image
SuhyeonK asked Felix Möhlmann commented
PF delay processing time or how to visualize remaining time
I use delay in PF, and I want to see intuitively how many seconds that time is left, is there a way to see it in dashboards, PF, and model?
FlexSim 24.0.0
processing timepf delay processing time or how to visualize remaining time
Felix Möhlmann answered Felix Möhlmann commented
When you click on a token in a Delay activity you can see the entry and exit time in the properties panel.
In the code of the Delay activity, you could also store the delay time and/or exit time somewhere (for example a global table) before returning the value. This data can then be displayed in a dashboard via a Calculated Table. Or used as input for text objects in the 3d model.
delay-timer.fsm
delay-timer.fsm (31.8 KiB)
· 5
SuhyeonK avatar image SuhyeonK commented ·
great! you gave me the best solution!
How can i input for text objects in the 3d model?
Felix Möhlmann avatar image Felix Möhlmann SuhyeonK commented ·
In the "Text Display" code of the text object, set the value of the "textnode" to what should be displayed by the object.
delay-timer-1.fsm
delay-timer-1.fsm (32.4 KiB)
SuhyeonK avatar image SuhyeonK Felix Möhlmann commented ·
great!! you are best!!!!!! how can I study about Flexsim Script
