How can I set the Refill Mode and Refill Rate for a Source object in FlexSim using FlexScript, similar to how I set the maximum content with setvarnum(newObj, "maxcontent", 10);
Hey @Daniel ,
You can use:
// Refill Mode: 1 Continuous Refill - 2 Complete Refill When empty setvarnum(newObj, "refillmode", 1 /*1 or 2*/) //Refill Rate setvarnum(newObj, "refillrate", value)
Thank you so much. How about output port, How can I set the maximum object and maximum port rate in flexscript? Thank you for your help!
@Daniel ,
// Output ports - Maximum Object setvarnum(newObj, "maxobjectoutrate", value); // Output ports - Maximum Port Rate setvarnum(newObj, "maxportoutrate", value);
13 People are following this question.
