Pooja I avatar image
Pooja I asked Paula LG commented
Turn table parallel work
Hello Team,
I have worked on the model through process flow. (Please check)
The robot 1 will pick and place box on turn table (10 secs)
The table will turn on other side, robot 2 will work on it (20 secs) therefore parallelly robot1 should pick and place box on other side of turn table
kindly see attached model.
Thanks in advance
Turn table with 2 robots.fsm
FlexSim 25.0.0
robotturntable
Paula LG avatar image
Paula LG answered Paula LG commented
Hi Pooja,
I have built a logic inside your model that works according to what I think is the best approach for this matter.
I have changed the use of resources to lists to be able to achieve this parallel work, and I also changed the turntable from a queue object to a basic FR that contains 2 smaller queues inside (which represent the position on each side of the table), because it is not possible to manually set the location of an item inside a queue (it strictly follows the stacking method chosen for it). You can relocate those queues and hide them to make the model more visually appealing.
I attach here the modified model: turn-table-with-2-robots_1.fsm Let me know if you have any questions about anything in it!
· 2
Pooja I avatar image Pooja I commented ·
Hello @Paula LG,
Speed considered for turntable is meter/seconds?
Paula LG avatar image Paula LG Pooja I commented ·
The rotation speed is defined in degrees/second, as the activity field specifies:
