tristan-dionis avatar image
tristan-dionis asked tristan-dionis commented
how to wait until the processor has finished the pallet before combining?
Hello, I had programmed the reloading of a pallet following a passage through a processor with a scrap rate. Delivery on pallets is done by queue to a combiner (with a code to have a variable number of product) but the pallet arrives earlier on the combiner. The combiner loads the products present in the queue but there is always a product in the processor so the pallet leaves without it and therefore the product ends up on the next pallet.
How can I ensure that the loading on the pallet only happens once the processor has finished all the products on the pallet?
Thanks in advance.
Tristan
2.12,12_Modèle frigo_gestion palette_ Finishingline1PN.fsm
FlexSim 24.2.1
combinercodeproduction line
Felix Möhlmann answered tristan-dionis commented
I'd use a small Process Flow. The separator is set to not release the pallet on its own (return -1 as port for the container). Instead, when its content drops to 1 (only the pallet is left), a token is created in an Event-Triggered Source. This token then waits until the last item has exited the processor, then releases the pallet to the combiner.
21212-modele-frigo-gestion-palette-finishingline1p_1.fsm
tristan-dionis avatar image tristan-dionis commented ·
Thank you it's perfect !
