I just upgraded to FlexSim version 25.0, and I have noticed that the Basic FR object is no longer available in the object library.
Can anyone confirm if this is a bug or an intentional change in this version?
Thank you!
Thank you!
This was an intentional change. We removed displaying the BasicFR and BasicTE in the Library view. The classes are still available and usable for models or user libraries with those objects.
Those classes are used for advanced custom object creation. Removing their visibility simplifies learning the software for most users.
If you need to create a brand-new instance of a BasicFR or BasicTE, you can create one using FlexScript:
Object.create("BasicFR");
Object.create("BasicTE");
You can then add your object to a User Library to view it in the Library.
Hi @Phil BoBo, could you please add this in the release notes ?
Removed displaying the BasicFR and BasicTE in the Library view
https://docs.flexsim.com/en/25.0/Reference/ReleaseNotesAndHistory/ReleaseNotesAndHistory.html
Can you also please update the tutorials below ?
The instructions ask to drag a BasicFR from the library but it's not there anymore. Users will fail the tutorials at this step.
https://docs.flexsim.com/en/25.0/Tutorials/FlexSimBasics/1-4LinkModels/1-4LinkModels.html#add
10 People are following this question.
